I have a little issue.
Since adding the power commander I can't seem to get the tickover down on the ADV. The BBS are set to about 3/4 out from full in but the revs are still around 1200 rpm. I synced the throttle bodies and they are pretty close, but there is still vibration through the bars at 80+. The bike pulls like a train, but I know it's not quite right.
What is the best way of setting the BBS. I keep hearing they should be 1 3/4 turns out, but if I do that the tick over is too high.
Do I need to tinker with the TPS voltage?
The power commander is set to run off the stock maps but target 13.8 AFR.
