Throttle, stop moved ZERO
Stewart H
North Wales
In the process of replacing my ticking left side throttle body, the stop screw has been moved, anyone know a rule of thumb setting that will make the bike run properly?
I have connected my multimeter to the TPS and can easily set the voltage but its not right, I seem to have lost the baseline setting., I have cleaned the Brass screws and blown through the drillings, but they dont seem to affect the idle speed or balance using a manometer. in the old days butterflies could be set using a twist drill of the correct diameter.Suggestions please.
Stewart
i'm pretty sure there's a how to on ADVRider. search for zero zero.
