"Through" Lyon or "Around"
Our Gee
North Yorks
Hi all,
please can anyone offer advice as to the direct route through Lyon. Many times we have have used the eastern bypass ie A46 / N346 to rejoin the
A6 / A7 either north or south of the city. But looking at the map I see that the A7 / A6 does pass more or less directly through the city and this would save about 15 miles. Any known problems or is it best to stick with the eastern route.
Thanks.
It's probably quicker to go straight up through the middle as the ringroad gives the city a pretty wide berth. It is dual carraigeway all the way and if you avoid the usual rush hour times you shouldn't have any holdups. :thumb2
It depends on what time of day, whether you are on a bike or in a car, maybe to a degree how good you are at filtering and 'pressing on'.
I used to go through the city in both directions about four times a year for a while, whilst my parents lived in Provence.
It can get blocked. Two Saturdays ago, the queue coming northbound into the city from the south was about five miles long. That was mid-afternoon. There was no queue of any significance coming from the north, though there was a delay of about an hour about 10 miles southbound well past the city, simply due to the volume of traffic heading towards the coast and (of course) to Spain and Italy.
Coming back on Wednesday morning, there was no significant hold up going north (a bit where the traffic divides, just before the first tunnel by when it's too probably too late to cange your mind) and about a mile long queue coming south, starting before the first tunnel in their direction of travel.
In short, you can never really tell.
The trick (if there is one) is to look at the overhead displays above the motorway as you journey along. If it says there is a 'bouchon' (a jam) - or summat similar - up ahead, then there probably is. Coming south, when you get to just before the 'tuning fork' / infinity symbol that (nera enough) marks the point where the motorways have divided, you make your choice, left or right. Stay on the A6 or take the A46.....???
Just a bit before about this point here... make your mind up..... https://maps.google.co.uk/maps?q=ly...oid=NrMmvJLsr_RN4M1QGsXznQ&cbp=11,172.21,,0,0
Coming north, start to make a choice as you appraoch the Rhone river. Nobody from UKGSer will be with you at that point, so it's down to you.
9 out of 10 times I take the city route... and regret it maybe twice. The outer ring road alternative is OK anyway, so you won't lose too much time if you go that way.
Thanks fot the info chaps, think I'll stick with the eastern route. As I said before it's only about 15 miles extra and the many times we have been that way I've never had a hold-up.
I try to avoid Lyon and skirt around using the new airport bypass - one can race the TGV too :D
