I am selling my Shroud coat as I have bought a new one which is slightly smaller, excellent bit of kit and cost me way over £250 but as they are having a sale on I have priced mine at £150 posted, it is in excellent condition with no trips or tears and will keep you warm
A little info about it below
A unisex zip-through black overcoat, waterproof on the outside and fleece-lined on the inside. Built for standing your ground in cold, wet conditions. Hours spent on the hill waiting for a weather window, long waits on the riverbank, the overnight shift, the early start in a wet field. Whilst you're static, the Shroud is at work. And it does not compromise.
Cordura® 70D outer fabric delivers high-tenacity abrasion and tear resistance across hard-use days in exposed conditions. Built to withstand sustained contact with rough ground, wet vegetation and the punishment of time spent in wind and rain. The pile fleece lining is treated with Polygiene® antimicrobial technology. Fleece can begin to smell when repeatedly exposed to wet conditions; Polygiene® is a bluesign® approved, plant-based treatment that keeps the Shroud lining fresher for longer.
The black Shroud carries a 3,000mm HH rating, offering reliable protection for cold, wet everyday conditions.
The Shroud is cut with an oversized fit, designed to accommodate bulky layers or technical equipment, or to provide enough room to get changed underneath. To wear as a regular overcoat, consider sizing down. Pockets are arranged for practical use at every stage: front chest pockets with double welt closing, large lower flap pockets with velcro fastening for stowage, side-entry hand-warming pockets and an internal zipped chest pocket. Engineered hook and loop cuff adjustment tabs lock out the elements at the wrist.
