martyn2974
Hi
got a tt rider pro,trying to fit it to an F800GS.Tried wiring direct to the battery via inline fuse but it flattened the battery over a couple of days(the unit was actually removed,i'm guessing the mount draws current even when the unit is removed)
i have now decided to run it via the din accessory connector.Does any one now if the accessory plug is switched via the ignition .And does anyone where i can get a water resistant din plug (in the uk)to wire onto the tt power lead.
