Sooty09
I have noticed a lot of F-GS riders are buying Givi or Touratech rear carriers and then fixing Top box plates to them. There is no need to fit an intermediate plate, by fitting two spacer tubes the Givi top box mount fits on the four existing points fairly easy.
Remove the caps and screws from the rear grab rail mount and make two spacers to make a level mounting base
Next lay the Givi base over to estimate the 4 fixing positions. Drill the base and chisel away part of the plastic stiffeners to allow a large washer to fit flat on the base.
Fit washers and bolt into place.
Fit the trim plate and test, check seat removes easily.
Note, this method pulls the box over the back of the seat. Removal is still easy but it will reduce pillion space. Its not possible to move the top box further back without an adapter plate.
We have used this method on a GS 650 for the last 6000m without a problem. The pillars under the back of the top box plate make a great place to fix elastic hooks.
