i have searched the forum so sorry if this has already been covered.
the man who is doing my gearbox and putting a longer fifth gear on told me about a mod to the torque arm. my driveshaft is on the way out and i asked him about the various driveshaft repairs and upgrades that are around. he told me that if you machine the torque arm and make it adjustable in length. then, when the bike is high on the suspension you can shorten the torque arm to make the bevel drive line up perpendicular to the swing arm. then the idea is there is less wear on the lower universal joint because it isn't running at an angle. also as the swingarm moves up and down, the spline can move in and out easier because it is in line with the shaft and getting pushed at an angle. this means there is also less force being pushed up to the top UJ and making that wear.
then hopefully the shaft will last loads longer because isn't it the increased angle the r100gs shaft runs at that that wears shafts out?
anyway i thought it sounded convincing but would love to hear if anyone has tried it or knows more before i try it.
