Torque Wrench Questions....
Grumpy Lee
Ex Supported Member
Yeovil-ish
Could somebody explain in nice easy terms all the ins and outs of torque wrench specifications to me as I seem to have got confused trying to find out for myself.
What is there a difference between in.-lb and lbf.in?
Then there are N.m., Kgm and mKg, I presume these are different as well, is this where we are being metricated (or worse)?
Last question, I have just had a "sort out" and find I have two torque wrenches, one 0 to 80 ft-lbs and one 40 to180 lbf.in (4-20 N.m). Will these be sufficient to cover most jobs on my 1150, or do I get rid of them and get one that does the lot?
I, as usual, look forward to the helpful answers I hope to recieve as well as any general pi$$ taking without which these forums would be sooooooo boring :D :D
in lb stands for inch pound, and refers to the turning force applied.
lbf in stands for pound force - inch and is the same as an inch pound...
N.m stands for Newtons meter, and as you say is simply a metricated version of pound inch.
kg m and mkg are metre kilogramme and kilogramme metre (ie the same) and are a bastardisation of the metricated unit.
Roughly speaking 1 Nm = 10 kgm = 8.85 lbft
a conversion site is here... (click the torque tab)
http://www.nmbtc.com/Calculators/converter.swf
sounds good, i think they should do most jobs on an 1150. possibly not the telelever ball joint.
Any help?
The torques wrenches you have will cover a larger number of jobs on a 1200 engine so don't get rid and the figures will be similar to the 1150.
http://www.r1200gs.info/misc/torque.html
You can never have enough torque wrenches...unlike talking wenches.
Ouch, sorry Sarah....
Timpo.
One thing to bear in mind is after using a torque wrench you should always take the pressure off them ie unwind the spring tension otherwise it becomes weak and not give you a true torque setting. :thumb
