Touratech Fog lights
Will.i.am
London
Hi everyone,
This is my first post but have been using the forum for a while now.
Bought a 2012 GSA a few weeks back, love it to bits.
It came with two touratech fog lights which i use continuously. One was not working at first, so i replaced the bulb, then both have been working for a couple of weeks until today when i realised both have now stopped working!
Bulbs look ok so im not sure they have blown, although nor did the original one i changed?
Any ideas?
Hi Will.i.am and welcome to UKGSer
Check the fuses, the wiring connections and the relay........I had a set on my R1150GSA that i'd fitted to my bike myself and had a faulty connection after a couple of years caused by some corrosion on the connectors.
Give everything a wee 'waggle' to see if you can get the lights working again and spray all the exposed joints and connectors with WD40 or something.
Hope that helps
FP.
Thanks,
Where would the fuse and relay be situated on the bike? Can't seem to find them! Don't really know anything about the electrical system on this bike!
The bike doesn't have a fusebox like you may expect, as the usual stuff is taken care of by the canbus system.
But the aux. lights are an 'add-on' when the factory set-up is fitted and it has a fuse plus a relay wired in. Follow the wires back from the lights. But if Touratech lights have been added - who knows.
