Touratech pannier lid seal leaking
(RIP) Bin Ridin
Dublin mostly!
Hi,
I have a 2 year old LH Touratech pannier letting in rain water through the lid seal.
Pannier is as new, and lid fits perfectly. Seal looks fine.
The external visible gap between the lid flange and case rim is about 1mm to 2mm at the front of the case, less at the back. It leaks at the front.
I though I could move the lock down a bit to lessen that gap but the 4 screws holding the lock are a tight fit in the case holes so no movement available.
Has anyone had this issue and found a solution?
Bin
Hi,
Bin
Are these the panniers with the locks/opening available on either side?
If the seal is easily removable, and the shape allows it - try removing it and refitting it 180degrees reversed. EG swap it so the seal from the hinge end is now at the opposite end with the lock
Hi Sangbar,
Thanks for reply. I will contact AMI who supplied the panniers, they may have a fix.
I will keep in mind your suggestion, was thinking about lifting the seal out of the groove and laying in a packing of some kind. Don't want to use goo because it will be very tedious to clean out in future...
Bin
