Sold TOURATECH SIDE STAND BASE EXTENSION – BMW R1300GS
Jondd21
Wales
Model Fitment BMW R1300 GS and Adventure. Active suspension model.
New in original sealed packaging.
£45.00 posted to UK address.
Touratech Side stand base extension - BMW R1300GS
The Touratech side stand support extension increases the contact surface of the side stand of the R 1300 GS by more than twice! From now on, the exhausting task of picking up a fully loaded load is a thing of the past.
A well-known annoyance that has cost most motorcyclists their last nerves! Soft ground. It starts with hot asphalt and continues over wet meadows until the end of a tour on the sandy beach. As a rule, a board or similar documents are never handy when they are needed.
The Touratech extension allows the vehicle to be parked safely on any ground!
By a fixed attachment of the support widening, this is always there and a lot of trouble and frustration are saved by this useful accessory. A mix of stainless steel and black anodized aluminum gives this extension a great look and full stability.
Last but not least, it should also be mentioned that folding out the side stand is made much easier thanks to the jagged shape of the plate!
Details:
  • Developed to fit the side stand of the BMW R 1300 GS
  • more than twice as large contact surface
  • Proven, robust sandwich construction made of stainless steel and black anodized aluminum
  • Easy to assemble
Every 1300 boxer heavily loaded with luggage will be happy about the 200% bearing area of the Touratech side stand support extension!
