The 2.2 Transit engine , is not one of Fords best efforts .
The 2011 Transit was/is the subject of a recall , there is a problem with the oil pump ,
ford are replacing the pump with a higher output unit. The Standard pump starved the engine of oil , the turbo was usually first to get hit , then the usual ensuing mess associated with turbo failure . You get the jist ! ...There is another problem with
these engines , the ECU is directing the Fuel pump to send too much fuel to the
injectors ,which is burning at the Top of the cylinder causing all kinds of nastiness ! ! ..
Any how , Ford are warranting a lot of these engine failures . This { Ford dealer} should be your
first port of call .
Ford N.I. replaced an oil pump on a 2011 transit minibus for me , and remapped the
ecu to try and allay the ecu problem ..
If you have used the correct oil , 5W30 fully synth , and preferably Ford low ash , and
can prove it ,, you could be on . ? . Maybe .
The first thing to do is establish why your engine has failed . Ford will tell you when you roll up to the door . You must be sure of this before you fit another motor .
I would ONLY BUY from an engine Remanufacturer that is going to
Warrant the Engine . The Engine will have to be remapped by Ford , to suit the
Bus , I have tried and cannot find anyone else that can do this and warrant it.
There are lots of 2.2 transits up and down the country with knackered motors,
DO NOT BUY one from a breaker . Unless your hear it running listen carefully. If you take any advice
HEED THIS .
