Tray under rider seat....drainage holes ?
Flipper_Man
Thame, Oxon
....does the tray under the seat, that appears to hold the ECU, have drainage holes ?
Just replacing an Autocom unit and noticed its full of water....which can't be good can it ?
Yes but they block easily - they are on the rear corners, just need to poke a small stick in to clear the hole then the water will drain out.
Yes but they block easily - they are on the rear corners, just need to poke a small stick in to clear the hill then the water will drain out.
Ah - might not be level on my drive, I'll have another look tomorrow after my ride in. We've had a shit-load of rain here and I was away last night so its just sat there for 2days.
Each time that I have been out in shitty weather they seem to get blocked by crap thrown up of the rear wheel - it is easiest to 'attack' the problem from below with a 1mm diameter stick or similar, the two holes can be hard to find but they are there. I am referring to my 2015 GS not GSA but I bet they are pretty similar.
