Colonel
So a good mate of mine rides a 2011 1200gs, but I won't hold that against him
Many years ago he lost an arm in a bike accident, so rides with only his left arm. He has managed to sort throttle, brakes and clutch but we are struggling with a sensible solution to the indicators. At the moment there are 3 micro switches mounted in a machined aluminium casing (right, left and cancel) however the slightest bit of wet and they fail. On his other bikes he has a separate on/off switch for left and right. Does the collective know if the bmw can be wired in a similar way or does the complexity of the thing prevent this? If not any other bright ideas?
Many years ago he lost an arm in a bike accident, so rides with only his left arm. He has managed to sort throttle, brakes and clutch but we are struggling with a sensible solution to the indicators. At the moment there are 3 micro switches mounted in a machined aluminium casing (right, left and cancel) however the slightest bit of wet and they fail. On his other bikes he has a separate on/off switch for left and right. Does the collective know if the bmw can be wired in a similar way or does the complexity of the thing prevent this? If not any other bright ideas?Cheers
and did it to the RT maybe if he has access to post 2010 RT switch gear it would help as obviously the RT 1200 would have can bus
