Cam
Fitting two TT Micro DE fogs to my adventure (1150) to use primarily as daytime running lights.
Do I need to install two relays, two fuse units and two switches as provided or can I run both lights through one relay unit , switch and fuse ? (or any combination of the above).
Am I right in thinking that these can be upgraded to HID? (looking at other posts here). If so, this is a route I will take, so it would be good to install most of the required cabling now.
First real attempt at any electrical install on my bike so I would to do it properly for a change.
Thanks for any advice on this.
Its a motorbike FFS
