Turning off the headlight
JohnG12
england
I know the answer is on here somewhere cos I've read it before. I'm unable to find it for some reason though
Can anyone please give me a headsup as how to turn the headlight off on the 1200?
Just want to try running with the lights off for a change. No, I don't know why either!!:augie :D
DOH!! Just found it :blast Thanks Mouse :thumb
''How to turn off the dipped headlight - or rather cause it not to turn on in the first place.
Turn on ignition
Hold down indicator cancel button for 5 seconds
Hold down right indicator button for 5 seconds
Start engine'' :JB
There is only one way to do that on my Scarver; remove the bulb.
Not kidding!
:) Liv.
As soon as the back wheel rotates, which it will do in neutral on the centre stand unless you stop it, then the headlight will come on again. You cannot ride the bike with the headlight off unless you disconnect the bulb.
That all depends on the year of the bike. On my 05 model, the light stays off until the ignition is turned off and on again. IIRC it changes at 08 reg
