Tyre fitters around Exeter Plymouth
  • Thread starter Thread starter Gray Wizard
Gray Wizard
Hey guys,
Off to Santander next Wednesday. I'm looking to change to 'nobbelies' before I get on the ferry (they are already in my shed :augie). Any recommended tyre fitters not too far out of the way? (Exeter, Plymouth). I have tried Ocean and they want £140 just to fit them :eek:!
Pro-tyre (Gupa-P) in Plymouth usually stock TKC's but it's worth ringing them to be certain and book a time.
01752 228118
They are easy to find and just off the route to Millbay Docks, in Plymouth.
Rear TKC from them in August last year was £57.50 + about a fiver for balance and a valve.
Front was £48.45.
They will let you remove your wheels and just pay as a loose fit if you prefer.
Fitted, it works out a little dearer obviously.
Give me a shout if you need directions to their place.
Edit just read your post properly!
They will fit them for you but again you need to ring in advance. I think they will charge you about £15 for a loose fit if they don't supply.
Failing that I know of a place just outside Plymouth, off the A38, that will fit them for you.
On Marsh Barton ...
... are two tyre places that offered TKC's, but had widely differing prices. Phone both for a quote; sorry, don't have contact details to hand.
About 15 miles from Plymouth, just off the A38 is DMS Motorcycles run by a bloke called Dan.
Nice bloke, doesn't do writing and sums but is a good independent motorcycle mechanic.
He will fit and balance your TKC's for you dirt cheap. He'll probably store and re-fit your other tyres if you asked him to.
Tel 01364 73157
If you need Mapsource location, it's attached.
Tell him you were directed from this forum.
Great - all sorted
Thanks guys!:thumb2
Dan at DMS is doing it for £15 - can't get any better! :D
