Ultrasonics
Redboots
Member well-known
Deep in the Vosges du Nord
Does it work? £110 is a bit too much for an experiment.
Now theres the question.
I live in France and trying to find anywhere that that does bead blasting or any other form of cleaning is like looking for hens teeth.
I found a company that sels this kit here and thought it "might" be worth the investment. I'm going to talk to them in the next week or 2 and see what gives.
John
I used to use them in the aviation industry. They work ok in some applications but do not bring up stuff anything as good as a good old fashioned bead blast. They basically just de grease.
" Reaches the smallest blind holes, grooves, threads, cavities, and crevices normally inaccessible to other cleaning methods without risk of dammage."
i know a manufacturing jeweller that uses one for just that purpose (oh - and cleaning jewellery!)
seems to be the best feature about it. :nenau
mind you- the times i've had to clean carbs for e.g. - and have never been really sure if i've got all the crap out of the orifices i cant see into.....
hmmm.... i wonder if a "marital aid" type product would do the same - i mean.... it's all to do with vibrations innit? :green gri
oh yeah - that'd make a good thread;
take one rampant rabbit with fresh duracells place in a bucket of gunk - add bing carb and leave to ...... :eek:
:D
I've thought about getting one of these type of ultrasonic cleaner, for its correct use :augie, but it seems quite a lot for what is basically a transducer and a tank for the solvent.
Further to this, has anyone tried to make one, using the ultrasonic transducer from a mist machine, the type that sits in a bowl of water? It would certainly be a cheaper experiment.
Just a thought
Nick
http://www.maplin.co.uk/Module.aspx?ModuleNo=35215&criteria=mist generator&doy=30m1
