russell
2006 1200gs--- I've fitted a set of nippy normans up and back risers. Fed the brake pipe under yoke. brake and clutch pipes now rubbing on yoke. I've put plastic tubing on both pipes for now but has anyone got a better permanent solution please. Even worse now the job is finished I notice that when on full left lock the throttle cable is being stretched. the plastic outer cover of the throttle cable seems to have come away from the end of the cable by about an inch or so (unless it was always like that and I did'nt notice). the bike is running fine but I'm a bit concerned. Is this normal with these risers or am I in trouble. Is it just a case of avoiding full left lock. Any info please
