USB port on X Country
bigmo476
London, England
Anyone found a place to install a USB charger near to the clocks/handlebars? I’m looking at putting a quad lock wireless charger above the clocks using RAM mounts if I can make them fit.
Also, make of USB charger and instructions on how to wire it in as well because I’m a bit of a moron!
This is mine. It's mounted to the outlet on the front brake master cyclinder. You're best to connect it to a swtiched live feed, usually the tail light, rather than connecting it directly to the battery. Put an inline fuse in cable from the tail light cable in the feed to the USB socket as well.
