USB socket
a2zworks
Hobart
Hi all,
I've installed a USB socket to run/charge my iphone on my '00 GS.
As I have a mechanical brain and have no idea on how to do the wiring connection I need your help.
I would like to do it so that power is cut off to the socket when ignition is turned off, I have a 5 Amp fuse on it is this suitable?
Your help would be greatly appreciated.
I ran a feed to the front and rear of the tank. I used waterproof connectors so the socket can sit under the seat or under the tank till needed and plug in a tail with a cigarette socket on the end. I either tuck it into to my tank bag or have it at the handlebars. I wired them into the existing socket outlet on the R1150GS circuit at the fuse block.
Adrian
