Using GSA rear brake lever on GS
Boffer
Norfolk
Tried searching forums for this (apologies if missed thread).
Has anybody tried fitting the GSA rear brake lever onto a GS07?
Have already taken rubbers pegs off as I can not fully operate the lever and with such weak rear brakes every little helps. I have noticed that there is quite a height differential between the lever & the peg hence the thought of using the adv unit with its hinged element. BMW motorad will not confirm if the parts are interchangeable across the two models?????
Any help before parting with the cash would be gratefully received.
I used the touratech brake lever enlarger mate, works a treat:thumb, it was only about 18 quid, coz i had the same problem, size 9 enduro boots, the foot peg rubbers felt as if my foot was too high up, so removed em, feels alot better now, and the enlarger brings the pedal out more in-line with the sole of your boot
brake lever
Hi did you ever fit the Adventure lever is. If so is it a straight forward fit.
cheers
Peter
No!
Changed boots to something with a slightly thicker sole (needed replaing anyway!)
Got use to it now.
