Popeye
Had some time on my hands so thought I'd have a play around with some DZUS quarter turn fasteners and see if I could come up with a QR solution for Vern’s Worldbeaters.
The Dzus receptacles need to be pressed into the stainless steel frames. This can be done easily enough with a couple of old sockets and an engineers vice.
The DZUS Studs then pass through the panniers into the frames.
I figured five DZUS fasteners per pannier should be enough.
I retained the original bolt / mount at the bottom for security.
With five DZUS fasteners per pannier everything appears to be rock solid.
Nothing has vibrated loose after a quick 150mile blast round some Derbyshire "B" roads. I don't think they would stand up to any really serious off roading but for day to day use - brilliant.
I can now take the panniers off in literally 10 seconds per side and put them back on in 15 seconds.
All the original holes are still there for when I want to bolt them on "properly".
Just need to source some plastic caps fro the back of the receptacles to keep road grime out and some plastic bungs for the original bolt mounting holes to keep the water out.
Total cost about £25:00
