Maybe I was lucky.
Just plugged the satav into a USB port, ran the disc, selected the update PC and satnav option and both Mapsource on the PC and V9 maps on the satnav updated.
Perhaps the sun only shines on the righteous.
Can't upload the Garmin (unofficial?) pdf file as it is over the site limit for a pdf at 515KB is there a Moderator about who could lift the limit for this file as it is very useful??
In the meantime here is the text without the screen shots:
Loading Mapping onto a Nüvi, StreetPilot c5xx or 2820 or other ‘Mass Storage’ units.
1. Open ‘My Computer’
2. Right click the disc drive that has the update disc and select ‘Explore’
3. Go to the RGN folder.
4. If you would like to load the whole of Europe, open the ‘All’ folder.
5. If all of Europe will not fit, then you can use sections of Europe as detailed below.
[NOTE from HH - 'All' will fit on a 2820]
However if your unit was preloaded with just UK and Ireland, then you will need to transfer UK and Ireland back onto the unit as there is not enough internal memory available for any other region. You can find the UK and Ireland mapping file by selecting the RGN file on the update DVD and clicking on the ‘ukireland’ file, you can then follow from step 6 below:
a. Region A - Europe North Central
b. Region B - Europe South West
c. Region C - Europe South Central
(All of the above regions are found in a sub folder found in the RGN folder of the DVD.)
6. Once you have found the desired file, minimize the current screen, open your unit in ‘My Computer’ and go to the ‘Garmin’ folder.
[NOTE from HH - you need to have the 2820 in 'Mass Storage' mode - not 'Garmin' mode to see it as a drive in My Computer - choose this on the unit after you plug it in to the UBS port]
7. In here there will be several files, we are looking for the GMAPPROM.IMG file, once you have found this delete it by right clicking the item and then choosing DELETE from the menu.
[NOTE: from HH - I was also told to delete a file called GMAPSUPP.IMG as it was a previous, failed attempt at loading by Mapsource]
8. After deleting the file, go back to the screen you minimized earlier, and drag the chosen RGN file to the Garmin folder on your unit and this will begin the transfer process.
[NOTE from HH - takes about an hour to transfer]
How to unlock this mapping file to your unit
If you try and turn the unit on after transferring this file it will display the maps locked screen, to resolve this please do the following:
1. Go to ‘My Computer’ and select your unit
2. Once you have selected the unit go to the ‘Garmin’ folder.
3. Click options along the top toolbar of the open window, then select folder options. Once the box appears, select the VIEW tab along the top and un-tick the ‘Hide extensions for known file types’, then click OK.
4. Once you are back in the Garmin window you will need to right click the window and then choose NEW > Text Document:
5. Once you have the Text Document appear in the window you will need to name it: gmapprom.unl (you may need to remove the .TXT extension).
6. Once the file has been created, right click on it and choose open. A window will pop up asking you to choose the program to open the gmapprom.unl file, you will need to choose NOTEPAD and make sure the box at the bottom that says to always use this program for this file type is un-ticked and then click OK
7. You will then have an empty document open, in here you need to type your version 9 25 character unlock code all in lowercase and without spaces or ‘-‘. After entering this, save and close the document.
8. You can then unplug your unit and the mapping will be unlocked and ready to use with City Navigator Europe Version 9.
Good luck - I found it worked perfectly.
