virgin
  • Thread starter Thread starter streffie
streffie
Hi all im looking at buying a gs adv, and wondered about a couple of things ?
1,which is best on fuel, gs or gsa ?
2,Tobinators ? what are they ?
3,low 1st gear or standard ?
Thanks in advance
Nathan
Welcome
1. Very Similar MPG but GSA has bigger tank, so greater range but more weight when full
2. Tobinator's are a system of add on brackets that provide much more adjustment for the standard screen, so give better options for controlling wind buffet over your helmet
3. I don't have the low gear but wish I did as it would be very useful around traffic (I do commute on my GS) - of course it is intended more for off road
I suspect a few other opinions will be posted shortly - suggest get back to back test rides on both models and then if you like both, and can afford both get the GSA
Wot he said:thumb
If you can afford the extra dosh, go for the GSA with all the toys (comfort & dynamic pack):bow. Or you could consider the GS SE, its like a GSA but with a smaller tank.
... low 1st gear or standard ?
Just a quick tip for you, but if you come across a bike and you're unsure whether it's got the standard or "enduro" first gear, ring the registration number through to a BMW dealer and their computers should be able to tell you. :thumb2
