VPNs
Disaster Area
New Zealand
I'm toying with the idea of a VPN for my home network.
Can anyone give me the pros and cons of using one?
Would I be able to stream UK stuff like BBC iPlayer and US Netflix without issue?
Do they provide an extra layer of security in terms of scams/phishing/malware - I'm also thinking about my not-exactly-techsavvy parents.
Any recommendations welcomed.
Cheers in advance,
DA
From a technical PoV there's only one real reason to use one for most home users - to make it look like you're accessing a service like Netflix from a different country to work around country restrictions. I do this to access UK TV etc from France but I use my own VPN server in a UK property to stream BBC iPlayer, terrestrial FreeView TV, Amazon Prime etc.
VPNs don't really add anything from a security PoV for someone just generally accessing the Net from home, and also add risk as you're trusting the VPN provider and their infrastructure.
It's a gimmick for most usage cases.
We use a VPN when away from the UK to stream TV content. I use nord vpn and it’s simple to set up.
one word of warning though. If you want to cast content onto a telly from an iPad ( for instance ) look for one which tunnels. Ie 2 channel
I also use Nord for the same reasons as above.
I prefer it installed per device. Some sites/services will not load with a VPN.
In France, some of the government sites wont load with it running.
My wife uses an app provided by her sisters care home and that wont work with it running.
My pal uses Proton when away and I think it’s free or something. I’d be interested if anyone can enlighten me.
Sent from my backyard
Very handy for shopping around globally for streaming services. Some good savings to be had.
If you are considering installing the VPN on the router then my advice would be that you should also ensure there is an alternative network available which is not protected by the VPN. Whilst you may be looking for a form of "blanket" cover, perhaps to ensure a nosey ISP cannot see your traffic, you should be aware that there are many sites that will not allow a log-in from a VPN. My example today is EON-Next, the electricity supplier! Absolutely no chance of looking at my account from an IP address protected by my VPN. There are many others.
Again, revealing my ignorance, I assumed that the VPN would be an app on the phone/laptap like Chrome and I just clicked on that to use it. I have no idea how to actually use one!
Yes, a VPN can be installed on individual devices and used on an as and when required basis.
Whilst it is possible to install a VPN account directly on to some more advanced routers, it is not something that you would need to do so don't worry about that
