Goosey Gander
It's very easy to modify a GS tank:-
1) With the tank in position remove the filler cap assembly and disconnect the two drain hoses, taking care not to drop them into the tank.
2) Pull the black oval overflow/ vacuum release case from its mount and replace with a 2 inch length of fuel hose. (This acts as a snorkel and will prevent fuel draining but still allows the vacuum to release).
3) Drill several holes in the collar of the fuel filler cap directly below the flange to allow for air displacement.
4) Replace drain hoses (it doesn't matter which way round) and re-assemble.
eh-voila! Now you can fill the tank to the brim. I have a photo of the drilled filler cap assembly on my website.
Goose
www.gooseontheloose.com
Goose
