I think I would suspect the caliper also. As said, my pistons push back easily with 'thumb' pressure. Defo no need to slaken the bleed nipple. If the seals in the caliper are on the way out, this would give you the symptoms you describe. However, I guess a faulty master cylinder would also do this but less likely as its not exposed to the level of road crap etc that the caliper receives.
