The morons in Maplin won't know what either is anyway. And its technical name is memory rubber. The description is "material that shrinks under heat", which is the dummy term, imho.
So "Go do one" as you might say.
you mean like this all of their web site
HEAT SHRINK
Refine Your Search
Department Availability Min Price Max Price
All Sections Blank Media Cables Components Computers Home & Office In Car Outdoor & Leisure Sound & Vision Tools & Services Toys & Kits Sale Items Clearance Items Sales & Clearance All States In Stock Within 7 days Within 14 days Within 28 days All States
Show Detail
Heat-Shrinkable Sleeving
heat-shrinkable tube with excellent flame-retardant, flexibility and insulation properties. it is suitable for the electrical insulation and bonding of cables and connectors and for corrosion-proofing of metallic rods, tubes and aerials....
BF86T 1.5mm Heatshrink 1m 5733 in Stock £1.41
PB21X 1.5mm Heatshrink 5m 176 in Stock £4.79
BF87U 2.5mm Heatshrink 1m 4320 in Stock £1.51
PB22Y 2.5mm Heat Shrink 5m 1156 in Stock £4.99
BF88V 3.5mm Heatshrink 1m 1613 in Stock £1.63
PB23A 3.5mm Heatshrink 5m 763 in Stock £5.22
Heat-Shrinkable Tubing with Adhesive Inner Liner
-a semi-flexible tubing with a meltable adhesive inner liner which flows when heated. after shrinkage and upon cooling this provides a moisture proof seal over the product covered. suitable for a wide range of applications, such as encapsulation of cables, wires, splices, breakouts and components. t...
KC45Y 3mm Adhv H/shrink 1m 463 in Stock £3.24
KC46A 6mm Adhv H/shrink 1m 398 in Stock £4.13
KC47B 9mm Adhv H/shrink 1m 190 in Stock £4.79
KC48C 12mmAdhv H/shrink 1m 542 in Stock £5.19
