Weep hole leakage from nearside
Have it checked.
I had a similar weep on mine and it was picked up on a service,the water pump was faulty and changed under warranty.
Have it checked and before you ride, do check the coolant level.
Sent from my SM-G930F using Tapatalk
What happens if whilst washing your bike you get water into the hole? Where does it end up?
Check the level in the header tank but it will probably heal itself.
My bike was exactly the same, one dealer suggested a new pump, the other main dealer said leave it but check the header tank. I didn't want the motor touching so I left it and it healed itself.
Although it looks like coolant has been pouring out you will barely notice any level drop in the header tank.
New pump. Had mine replaced and no probs at all
Similarly, my pump was changed too. As well as the weeping water, i noticed the temp on dash was scrolling up and down between 88 - 95 whereas normally its more constant around 90 (i think). This all stopped after the pump was changed.
Thanks for all the replies, been monitoring temp today, was static about 81 - checked fluid level and all seemed well. Not really budgeting for a new pump so gonna see if it develops further.
