Well as it says, I have a mates 1150 GSA in that won't run and I'd like any further options / pointers you may have
I opened the fuel cap and it's full of water so I drained the tank and mopped out the remnants and approx a litre of water and I drained the pump and changed the fuel filter, I then drained the injector tubes and flushed fresh petrol thru them
and did the same to the injectors with the injectors out of the T bodies
I charged the battery and checked connections and overhauled the starter
I can only get it to start and do a semi fast idle 1200 ~ 1300rpm giving it any throttle makes it stall and die off
So I thought okay it's been lying out so it must have water in the TPS I've swopped on a replacement I have and flushed the connection through with ACF50
It's made no difference So my thinking is that something is wrong with the ECU or Lamda probe
It runs smooth at the fast idle but shutting the throttle or trying to open it kills the bike So I didn't think it was H.E.S.
I can hear the fuel pump charging okay and there is 20 litres of fresh fuel in and no water the fuel
The spray pattern looks okay too "a good mist" about 4 to 5 inches long
New plugs
New fuel filter,
Serviced 2000 miles ago with a full Service and inspection
I have to admit this one has me confused unless he has wrecked the injectors trying repeatedly to start it and forcing water thru them???
BUt it starts and runs if your VERY careful with the throttle openings, So you'd assume that the hall effect sensors should be okay too!
Before someone suggests it is DEFINITELY NOT The Cables both butterflies quadrants are on the stops and both throttles are synchronised
So Anyone anything else that they could suggest?
Do you have Any suggestions?
New plugs
New fuel filter,
