WHAT BATTERIES??
theclowncrusty
In the setup menus on the Naigator you can change the type of battery in the unit. If you choose NI-CAD does it charge them up for you while the unit is running on external power?
The Clown:confused:
No it doesn't - you have to re-charge them off the bike.
Mike:)
The option is there to adjust the voltage derived from the batteries, Zinc lead or Alkaine batteries produce 1.5volts, Nicad or NiMh only produce 1.2volts so with 6 zinc or Alkaline batts the voltage would be 9 volts with nicads or NiMh the voltage would be 7.2 volts, the electronics of the unit require 5 volts hence the option.
