What type of bulb/lamp is this?
Deleted account 220427002
come on o' tek heads:)
and where can i get them?
Do they do the 50% brighter in them?
You can buy them here.
I have to say it looks exactly like an H4 but with a low-wattage dip beam filament.
Greg
Thanks for the link i was hoping to find the type so i might be able to get one locally or order the brighter lower wattage one:)
here is the h4 beside it on the right
CBRR400, geardriven cams:D I've got honda CB-1 400 , nearly the same engine. Does yours red line at 13,500 or is there more?
File or grind the notch out to suit on a standard H4 bulb, worth a go for the extra 20 watts on dip.
Yes, can see now that it's not an H4 - I did wonder why they were listed at almost £8 a pop!
Greg
dremill
sanding drum fitted and away you go, you'll then be able to use better brighter bulbs:thumb
I'd dremmel the light fitting itself, not the buld. Surely this would be easier?
