I HAVE BOUGHT A SET OF 1150 SPOKED WHEELS FOR SPARES/OFF ROAD USE,THEY ARE QUITE SCRUFFY BUT HAVE STAINLESS SPOKES.
THEY CAME DISMANTLED BUT WITH THE SPOKES STILL IN THE RIMS,THE PROBLEM I HAVE IS THAT I WANT TO TAKE OUT THE SPOKES TO CLEAN UP THE RIMS BEFORE REBUILDING THEM,BUT THE SPOKE HOLES IN THE RIMS ARE CORRODED,SO THE SPOKES ARE EXTREMELY TIGHT IN THE HOLES.
I HAVE MANAGED TO REMOVE TWO OF THEM THAT WERE PUSHED SLIGHTLY OUT OF THE RIM BY GRIPPING THEM WITH MOLE GRIPS WITH RUBBER UNDER TO PROTECT THE SPOKE,THEN TWISTING THEM OUT UNTIL THE THREAD REACHES THE HOLE,THEN TWISTING AND PULLING HARD UNTIL THE THREAD CUTS AWAY THE CORROSION.
ONCE OUT THEY WILL DROP BACK THROUGH THE HOLE.
HAS ANYONE ELSE REBUILT ANY WHEELS,AND DID YOU HAVE THE SAME PROBLEM.
OR HAS ANYONE HAD TO REMOVE ANY BROKEN SPOKES,DID THEY COME OUT EASILY
OR DOES ANYONE KNOW OF ANYHING THAT I CAN SPRAY OR BRUSH ON OR SOAK THEM IN THAT WILL DISOLVE THE ALLOY CORROSION BUT NOT DAMAGE THE ALLOY.
BY THE WAY I HAVE REBUILT MANY CONVENTIONAL SPOKED WHEELS AND DON'T SEE WHY THESE SHOULD BE ANY MORE DIFFICULT IF I CAN JUST GET THE BLOODY SPOKES OUT.
ANY ADVICE WOULD BE WELCOME.
