Where is the horn located on an XR250R??
  • Thread starter Thread starter Marjorie Proops
Marjorie Proops
Sorry for the daft question chaps but I have an MOT early in the morning and in the brief time I had to look this evening I couldn't find where the horn is actually sited - its not working and I won't have much time in the morning to search around.
I know that it doesn't work without the engine running BTW, but there isn't a sqeak out of this one - any common faults with em (2004 model) :nenau
Steve
Steve
OEM Mount is on left hand side of front engine downtube.
There should be a metal horizontal tang sticking out, just under the tank.
Guess you have the switch, but no horn.................most people threw the actual horn away
(just had a look at the For Sale pics again and it looks like it's not there:tears:tears)
Hi Steve,
Yes, I can confirm there is no horn assemble attached to the frame, I assume the wiring to the button is there ? I was told you can fit a small battery one for the purpose of MOT, I think, you can even get away with one of the squeeze trumpet one to go through the test :thumb
Good luck, Im sure she will sail through.
All the best
Richard
Hi Steve,
All the best
Richard
I was under the impresion that a bulb horn would fail an MOT, because it is not a continuous audible device.
Cheers guys, I've put back the MOT to give me time to fit a horn today.
I'm taking the 1150 in for MOT at the same time so maybe I can just stand behind the tester and beep the GS horn when he presses the button on the XR :green gri :D:D:D:D
Steve
Shouting GETDAFECKOUTTATHEWAYYOUBLINDTWAT at the top of you voice will have more effect than the standard strangled fart you get from an XR horn. :D
Hi Steve,
All the best
Richard
Just get an XR one from Ebay
Bulb (Air) Horns are a definitely MOT fail nowadays
All done thanks folks, GS and XR250 both MOT'd, new horn, brake pads and lights sorted for £110 including both MOT fees :thumb2
Steve.
Thanks Richard - sound bike :thumb:thumb
