Which Autocom or summit else...?
GS Bloke
Bedfordshire Village, England
Setup: Zumo 550 on 1200GSA, Bluetooth Phone.
I want to be able to hear the Zumo prompts, make calls and listen to music on the Zumo, not 2 bothered about passenger chat or bike to bike.
I have tried a Bluetooth helmet kit which didn't work out (made the phone drop out).
So here's the thing, I think I need a cabled solution and see that Autocom make various different models but I'm not sure which one does what I need.
Is there a model that will wire into my setup out of the box, or is there another brand that I should look at?
I would like the option to use or not use the system as I wont always be using the Zumo so it would be good if I can remove speakers/mics from my lid with ease.
Any recommendations?
Thanks.
Thanks.
As Rob K above, but at the moment have bluetooth phone, UE Monitors being made, Zumo still on wish list. Need to put together case for employer meeting cost of necessary kit in order that I cna take business calls whilst on the bike. What do I need and how much is it likely to cost? All advice gratefully received!
I use autocom with my zumo connected by 2 isolated leads which eliminates ignition 'humm'.
My phone is then connected via bluetooth to the zumo
I have found that all the features (MP3,GPS guidance and phone) all work as intended BUT the volume is quite low and virtually inaudible over 60mph
I wear earplugs and have the autocom and both volume controls turned up to max btw
To date I haven't found a solution to increase the volume:nenau
Try adjusting your speakers. It can make a huge difference. I had the same problem. I also used to position the speakers with the wire coming out of the top. I have now moved them the correct way and have the wire coming out of the rear. They then still needed fine adjustments so that the center of the speaker (which is offset) is exactly over the ear opening. Just a small bit out can make a difference. I would still like a bit more volume but music and sat nav prompts and phone is now audible above 80
