Which muffs?
Anyone using the Wunderlich muffs, blurb says they can be used with hand guards while you have to remove the hand guards to use the Tucano's
I've been using some Oxford ones for several years, work well....I did have to melt a small hole for the mirror stem to pass though though, but the end result looks neater than the Tucano ones IMO...none of that untidy stuff with string wrapped around :nenau :eek
EDIT PS Mine aren't furry inside , but I'd hate to think what wet furry muffs would be like :)
No if's or but's You don't have to remove the handguards with Tucano muffs.
Anyone know if the R317's fit the 1200GS (pre 08)?
319 Muffs are the correct fitting for the BW GS's
The 317 Muffs are the same, and will wit fine, except they are for use without mirrors fitted to the bars. So not much use on the GS's.
Val.
I have the 319s (Cheers Val :thumb2) on my 1100, they go over the barkbusters fine, though I did remove the plastic spoilers.
Stewart
