Which odessy battery 4 an 04 1150 GSA?
paddy dougan
wales
Hi all,
can any of you good people tell me which Hawker Osdessy battery I need for my 04 1150 GSA? Servoed ABS & heated grips.
I've got an intermittant fault on the ABS/braking system, when I throttle up, I think the alternator is drawing most of the battery power for the field current, hence the reset, bit nerve racking as I am then without brakes!!! The battery has been playing up over the last couple of months.
Any help/advice much appreciated,
many thanks on advance,
P:beerjug:
Battery
Batterys knackard, if it was the alternator field and it took that sort of current it would just go up in smoke!.
Hi Dave,
the battery or alternator???
The field current loading required on heavy throttle up is enough (if battery is not good) to cause a reset on the ABS/Elec Servoed system. I know the battery is not great because using the heated grips, even on a long run wipes out the battery charge. I had thought it may have been a short on the H Grips but I've since had trouble starting it (no real cranking power).
Anyhow, hopefully will have the odessey soon, recommend a trickle charger anyone?
again thanks for help/info,
P
Similar threads
