which winglets
autogs
bookham,surrey
just going to fit adv screen to my 06 1200,question is now which winglets bm or the nn ones which seem to be bigger ,anyone got any of the nn ones,any good?
cant give u a comparison to the BM ones as have only had the NN version,
quality is fine, but there are still a few cutting, smoothing marks on the edges that you might have to polish out.
The template that u get for the holes in the bodywork isnt the best - its slightly too big for the area so u have to make your own judgement on the final position.
i found i needed to put a small rubber packer between the beak "arms" and the screen support to stop the vibration when at idle and also to reduce the amount of flex in the beak arms when at speed - but u will get this if you have the BM version also.
for quality i would go BM as the edges are a lot nicer/rounded, but i am also happy with the NN version.
just make sure you use the large washers on the underside of the beak and dont overtighten the nuts/bolts as u may crack the plastic beak and then the winglets will depart company in the future
The BMW ones can be fitted in 20 minutes, even with drilling the plastic, and cost 28 quid including very nice screws and fitting, which is 3 pound more than NN. no brainer really.
thanks chaps i think i will go for the bmw ones,vines here i come
