Roymundo
One year ago I fitted some new LED auxiliary lights to my 2015 R1200RT. I purchased the after market lights off Amazon for about £55.00. The kit consisted of a pair of LED lights, wirering harness, relay and on/off switch. Lights have worked fine as they should.
However the original switch is corroded inside, not waterproof, so I have purchased a new waterproof on/off motorcyle switch, and now my puzzle begins.
The original switch has 3 spade connections on rear connected to the wiring loom:
One (yellow wire) to the trigger wire which becomes live only when the ignition is on.
One (black wire) connects to 86 on the relay.
One (white wire) connects to 85 on the relay.
The new switch is pre-wired into rear of switch(3 wires about 400mm long)with instructions stating where the wires are to be connect to:
One Blue wire. (connect to the equipment positive).
One Brown wire. (connect to Negative).
One Black wire. (connect to Positive).
I have no idea how this all works and don't like to mess with electrical stuff.
To avoid any electrical damage...Can anyone please advise which wires (blue,brown &black) on the new switch...... connect to which wires (yellow, black & white) on the loom connection?
