SJRoome
Hi
I am a bit of a fanatic about adjusting and cleaning the 40mm Bing carbs on my 1989 R100GS. After I had just stripped, cleaned, tuned and synchronised my carbs I went on a short test ride, ran out of fuel and switched to reserve. As my tank was rusting inside this promptly dumped a load of rubbish into my inline fuel filters and I limped home.
The story of how I tackled sorting out the rusty tank can be read here http://www.ukgser.com/forums/showthread.php?p=1861086.
After I had sorted out the tank I refilled with petrol and yes, one of the Bing carbs leaked fuel. Bing carbs are very prone to this. Enough very fine debris had got through the inline fuel filters to get onto the float needle to make the carb leak.
Here is an image of the float needle exactly as extracted from the carb. You will see there is a faint ring of debris on the tip, and that is what is causing the leak.
This debris may not look much, but under a microscope you can see it totally transforms the surface of the float needle.
All that is needed is a spray of carb cleaner and a quick wipe with a lint free cloth and the needle is as good as new. Alternatively rub the needle tip on a piece of clean cardboard. But of course I had to clean the rest of the carb too.
Steve
Steve
