Wilbers.....
Funners
Yorkshire
Posty turned up today with my Wilber suspension, a big UP to "Everyaccessory", extremely helpful, know their stuff, and their attitude is a nice refreshing change...
and..they Under promise and Over deliver:thumb told me 3 weeks delivered to my door in 2.5..
I opted for the "sportline" colourways rather than the stealth "classic" ones..OK I'm a tart...bite me !:D
Did the rear first, simple job achieved from start to finish in around 20 mins, inc faffing with the damping bottle...
theres a lovely alloy clamp for the preload but just some rubber blocks and hoseclips for the remote damper, still didn't look too bad when fitted, but ended up being the only thing I was slighty dissapointed with...:(
next I tackled the front, which while basically simple there were enough pitfalls to catch you out, I ended up removing the centre section of the crash bars, and the rear wheel again to give me enough lift to get the shock out, I also had to remove the tank cover to gain access to the top nut.
refitting was easy but, it didn't look right and I ended up taking it back out , eventually the penny dropped, theres a spacer on the OE shock which you need for the new one, at first glance this look like it's part of the shock rod, but no, it IS seperate and you DO need it.
Once I'd sorted this it all went swimmingly and around 15 mins later the bike was stood on its own two wheels again, I re-fitted the engine bars and the started on replacing the filler cap/tank cover....
Well what an UTTER utter Bas*rd THAT is !:spitfire it took longer to get the filler cap bolted back on than the rest of the bloody job !:nenau
eventually all the bolts went back in and the rest of the bike went back together in double quick time.
Dropping the bike down off it's centre stand my first impression were "very controled" throwing a leg over it for the first time, ride height with the hydraulic pre-load at min is roughly the same as the OE shock at Max, as it's sprung for my weight now, the bike gives but not too much, again damping feels taut...so far so good !
so first ride..now I'll be the first to admit, I've only managed about 5 miles on it, I've a lot on atm and ended up rushing slightly but, first ride impression are..
Taut ride, with nice damping, kinda firmer but plusher if that makes sense.. ?
over some ripple bumps, again it felt composed, a good test will be to see if it's lost that grip/slip feel whilst leant over on ripples...but that will have to wait till next time..:)
there is no longer a "sinking" from the rear when you gas it and it seems to tip in well in corners but again time will tell....
Over all first impressions are very positive, and seem to be worth the money, certainly if it stops me draggin the main stand around like a dog with worms I'll be well happy:cool:
some pics below...
I fitted some side panels today as well so the damping bottle ended up hidden after all...;)
They get even better with time, one of the best bits of "bling" for the 1200, just as the Ohlins were for the 1150.
To get the full benifit of these shocks IMO your going to want quick and easy axcess to the High and Low Compression Clickers, particularly when dialing them in. I've got about 2000 Ks on mine and I'm still fine tuning......
Enjoy the new sharp feel..........
Cool, sounds like you had fun fitting them. The more I read about it, the more I like the idea of some Wilburs.
Had a quick look on the everyaccessory site, but there are no prices, and no indication of which shocks I'd need for an 06 GSA (Also in white). I know that they need to know my weight, and riding style, but a rough indication of price so I know how long I'll need to save for.
I did a quick search on this site, but couldn't find definitive prices. Am I right though in thinking that they'll be around £800-900 for the pair? If so I'd better start saving.
Thanks, and enjoy the ride.
TobyS
Dremmel is your friend, I had to adapt the side panel to fit around the damper can anyway so two holes for adjusting the clickers happened at the same time;)
TobyS
If you go for the fully adjustable rear with hydraulic pre-load and the adjustable front then it works out about £950, however, if you mention that you are a member here you get 10% off which brings it down to around the £860 area...
not cheap but I reckon it's worth it...especially as now I can allow for pillion/luggage with no worries:thumb
ring them up and talk to them, they are nice blokes and know their stuff
Damping bottle? Damper can? If it's in reference to the large red knob attached to the frame then it appears to be a remote hydraulic pre-load adjuster for the spring which has nothing at all to do with damping.
I'm I correct in thinking that the shocks needed are parts 630 (front) and 640 (rear)? Then add on the adjuster if needed?
I though he was talking about the piggyback things that hang off the side. There isn't one visible in the pics, but I can see that it'd be a bit tricky to squeeze in there:
http://www.r1200gs.info/howto/mountWilbers.html
TobyS
Oh and does anyone want to lend me £800? I think I can find the £60. Best start saving TS
TobyS
there's another variation where the remote reservoir is not piggybacked ie. part of the shock body casting, but connected by a hose. the reservoir has to be fixed to the frame, sometimes with jubilee clips :nono
Ah hah! Renewed inspection of first pic reveals remote reservoir cleverly hidden behind jubilee clips. I was momentarily dazzled by all the new bling centre and right. :augie
Nope - there's plenty of room to fit the resevoir in if it's fixed to the side of the shock. That's how my WP Spin shock fits:-
Obviously, just one of them.... ;)
Sharp eyes that Cookie. And he's got the fancy Wiblers with the remote control wotsit, but being a cheapskate I didn't go for that particular bit of farkle.
LOL....:D I see you've spotted where it's hiding.. mounts to the LHS of the bike it's hidden in the side shot due to the side panel fitted...;)
yeah..kind of..
theres only one model for the front shock which I believe is the 630 this is £340 there are TWO models for the rear the 640 which is adjustable rebound only £340 or the 641 which has adjustable rebound and high and low speed compression damping this is £490, hydraulic pre-load adjuster can be added to both at £130, this last one is the one I went for as there is a fair discrepancy in my riding needs...from Solo "spirited" riding to two up, fully luggaged riding, Every A thought the 641 would give me more scope to cope with the variances inviolved..the "Bling Factor" never came into it...not even once..:augie
