Will Nuvi 255W accept *.gpx Files ??
Andy Hird
Scarborough,England
Hi Folks
I've downloaded ITN.Conv form the web, which allows you to create routes on Google Earth and export them as *.gpx files. Will the Nuvi 255W accept these files ??
Andy
not too sue of this helps or not but,
I'm assuming you use Mapsource with the Nuvi as Mapsource will take gpx files if your doing a route that you could then upload to the Nuvi ?
I don't think it will, check out the specs page on the Garmin website and look for the number of routes in the Maps & Memory section, if it says anything greater than zero it should accept routes either loaded directly from Mapsource or transferred via the SD card as a GPX file. I think the Nuvi 550, or greater, is the starting point in their range that will accept routes.
