Hi, I've searched the forums and found some info about powering the autocom on an 1150GS, but some of the info seems contradictory (to me
) in the best way to do it.
My 1150 has ABS and I'm unsure whether I can power it via the back brake light. A help document on the autocom website says...
'PLEASE NOTE if your bike has ABS braking and/or a brake light failure warning system you MUST consult
your bike supplier or manufacturer for approval before connecting to the brake light circuit. If connection to
the brake light circuit is not recommended, use some other ignition switched 12- volt supply, such as the rear tail
light live feed or any other recommended fused, switch ignition point.'
So;
can it be powered from the back brake on my ABS model?
or should it be via the normal tail light feed?
or should I do it via the back of the accessory socket?
A definitive answer would be greatly appreciated, thanks
Rich
) in the best way to do it.My 1150 has ABS and I'm unsure whether I can power it via the back brake light. A help document on the autocom website says...
So;
Rich
