Wiring for Halfords and autoswitch
(RIP) willstatt
Lost
derbys
I've just posted a query on the GSmods section about Wiring for lights and autoswitches, and would REALLY appreciate if one of you bright sparks could have a look, and see if you could come up with wiring diagram to help me achieve. the following:
I want to wire my Halfords spots so that one comes on with the dipped beam, and both come on with the main beam, with both switched with the autoswitch so they're not used in normal 'dip only' daytime use.
I'd really appreciate some help
Will
In order to get one lamp on with dipped beam, and the other on with main beam, you need another relay.
The connections will be identical to those with the kit you have, except that instead of connecting the relay coil to the main beam feed, connect it to the dipped beam feed.
