Wiring in new horn.
Gordon T
Chester le Street Co. Durham
Ive mounted a new Stebel Nautilus horn to the front of the bike.
Now, where do I source a plug that will go into existing connector for the standard horn? I dont really fancy cutting the plug off and joining the wires. Its only going to power a relay for the heavier loading for the Stebel. It would be a lot better as it would be waterproof and I can then hide the relay somewhere safe and hopefully water resistant. Gordon T.
Leave the standard horn in place (if you can) use two "Scotchlock connectors to take power from the existing horn to power the relay. Simple Cheap and you get a two tone horn.
Good idea dmilne. It may come to that in the end but I need to weatherproof the joins and would like to utilise the existing plug. Anyone know who manufactures the oem plugs?
Go into a BMW car dealership go to the parts department and ask for part number part number 80 00 0 611 656.
When the guy cant find it tell him its listed under tools and not parts. Mine cost less than £5.00
<a href="http://s579.photobucket.com/user/notcurleyboy/media/IMG_1035_zpscjqfhfpw.jpg.html" target="_blank"><img src="http://i579.photobucket.com/albums/ss233/notcurleyboy/IMG_1035_zpscjqfhfpw.jpg" border="0" alt=" photo IMG_1035_zpscjqfhfpw.jpg"/></a>
Yep. New relay is here. Horn mounted, just need the plug to connect it. I will try to get the plug before connecting to the loom as you mentioned earlier. Its tight under the tank and a plug would make it so much easier. G.
I was just looking at fitting a Nautilus to my 07 RTP to replace the crappy standard horn and wondered if anyone had any images of one fitted to an RT and the best location?
Of course my mate thinks I should try to utilise the original siren speakers to make a really loud horn but I think that will be more work than sticking a Nautilus on.
SB
