PeterNicholson
OK, folks - advice please:
Used the heated grips for the first time this year this morning.
L/H grip started getting wobbly when hot, as if the glue holding it down was melting. Grip was fine again when it had cooled down - don't tell me that B*W use hot-melt glue to hold the rubber on
Seriously, when I looked at the grips and took the bar-end weight off, there appears to be a heater element under the rubber.
The Question:
Is the element completely separate from the rubber? If so, can I slide the rubber off to re-glue it without damaging the heater element? Any tips?
Waiting patiently...
The Question:
