vaclove
I have reported some time ago problem with a side stand getting loose at the point where it is attached to the main frame. I've resolved this using Loctite.
Now however I have discovered that the joint which facilitates ejecting the stand stand has some play. I have tried to tighten it, but seems not possible. There is also the switch responsible for shutting down the engine when side stand is ejected and gear is selected. This switch also seems to have too big play.
could someone give me some comment whether this is the way it should be?
Many thanks.
Many thanks.
