OK, I've just taken delivery of a spangly new Dell PC with XP pro OS which is happily connected to my home network and connects to the internet through my broadband connection but I'll be buggered if I can get to see or be seen on the network so that I can transfer my files across.
All other PC's are 98 SE and are connected using CAT5 cable and a simple Netgear hub. I have entered the workgroup and given it a unique name etc but no joy.
All the 98 SE PC's use Client for Microsoft Networks and Client for Netware Networks in the configuration box although Microsoft is the primary logon. Under netware I can set F as the drive but this option doesn't appear in XP
Any help greatly appreciated before I start transferring files by CD... how inefficient can you get!
Thanks in advance.
Adam
P.S. Also, how do you rearrange the programs within the start pop up? In 98 right click and explore is the answer but apart from accessories the rest of the installed program files and their shortcuts don't appear.
I can see this XP is going to cause me some pain.
Thanks in advance.
Adam
