Stripping the carbs on an 82 xs1100 to get them ultrasonic cleaned, everything was going according to plan till I removed the air mixture screws, two came out fine, two came out with out the very tip. When I rub my finger inside the body I can feel the tip protruding. Tried gently to push back up with a screw driver but no luck, don't want to bend the brass top either as I could be in deeper sh!t. Plan tonight is to stand carb bodies on the stove for an hour with some wd40 to see will the heat release them. Any other ideas?* they ware obviously over tightened at some stage.
